310D backhoe
ben brown
does any one know what the pressure spec are for the forward reverse transmission i have 150 on reverse and some time 50 on front i know the 50 not enough
My guess would be 150-165 PSI, a bad piston seal would give you a low reading and slippage in that function..
that what i was thinking i had apart time or two last time it work good then was pushing snow it just quit the thing about it is it has 3 sets sealing rings be fore the oil gets to the forward piston going to take it apart again it not that big deal to drop the reverser also think that maybe the solenoid magnet doesn't have enough pull and you cant by replacement ones with out getting the complete manifold which is 1350.00 if you have the late model you can just replace the magnets. well see i get it apart
