Trying to diagnose an early 4020 synchro that has been getting harder and harder to shift into the 2nd range on the pattern. For example getting into 1st gear is fine, shifting into 3rd requires you to feather the clutch to get it in. Similarly, if you are in 1st reverse it is difficult to get it into 3rd gear. Once you get it into 3rd gear it doesn't slip or grind though. Acts the same in all the other 2nd range gears.
Linkages are not worn out and adjustment was checked per the service manual. With the top plate off the transmission no obvious problems are showing up. Even moving the shifter lever with the tractor not running is showing the same symptoms. Easy to shift into 1st range but requires you to twist the other gear shafts to get it into 2nd range. We're ready to split it but are we looking for a synchro drum that has some bad teeth? What else would you look for?
