Have a noise coming from what I thought was gov/fan shaft area. Took off fan shaft and still have the noise. Thought it might be in gov assembly which has been totally rebuilt but everything checked out as far as I could see with engine running. Took the whole gov off a few days ago, took out spark plugs and spun flywheel as fast as possible and heard a clanking metal sound which I believe thru deduction is the noise I originally heard... Could visually see this noise is coming from the gov/flywheel meshing @ every full revolution. Just by chance I had a friend spin the flywheel with the clutch engaged while I held back the clutch pulley actually 'braking' it and keep it tight with the flywheel. Low and behold no noise. Does anyone have a clue as to what might be going on with the camshaft or parts within that would cause this momentary delay of the cam meshing with the flywheel while the engine is running ??? Thanks and appreciate any help.
