4440 Transmission oil light
J. Schwiebert
On one of the 4440 tractors the transmission oil light will work like it should, the next time you use the tractor the light may not go out for 5 minutes. Where do I start to look for the come & go problem? Thanks in advance. J.
How long since hyd filter was changed & sump screen checked/cleaned? I'd suggest to check trans pressure. Pressure should be 155-165 psi. It's possible you have a faulty sender.
