Hi I have a John deere 4010 that I have been having issues for the past few years with when I push in the clutch I loose all hydraulic with in a few seconds I noticed that when I cap off the hydraulic line going to my brakes I can hold down the clutch for over 5 minn with no loss of hydraulics so I figured the brake valve was my problem so I rebuilt the valve and installed it back onto the tractor with same results. I then noticed that the hydraulic return line on the brakes will pump hydraulic fluid no mater if the brakes are pushed in or out being closed center I don't think this is supost to happen or is it? Thanks for any help.
