Harold Melius
I need a little info. I have a 1962 JD 2010 diesel tractor engine I am putting back together (serial number in the 17000's). I try my best to avoid working on diesel engines, so I don't have any manuals on them and won't be keeping the tractor. Does someone have the torque specs for the mains, rods and head on this tractor? Info seems to be a little hard to find for this model. 110 Lbs. seems to be the most quoted spec for the heads on a JD but I have also seen numbers as high as 150 Lbs. listed. This engine has the deck plate with the sleeves all attached, so I don't know which numbers to believe. Thanks
