6210 with cracked priority valve when you use the hyd the pump stay in constant pumping . have a jd repair and test and adjust manual.. replaces priority valve made sure all the disk were reinstalled now my stand by pressure is at 450 witch is with in specks 406-475 sensing pressure is at 50psi speck 29-87 psi. pump was going to max pressure of 5000 psi now it at around 2500 it should be 2900-3000 i can get it there. problem is it stays in constant pump under pressure even after you release the remote control lever back to neutral.. when it under constant pressure my sensing pressure goes back to 50 psi. with that, pump should return to stand by pressure but its not .. here what i am thinking that the valve piston in the pump that control the swashplate is sticking or the flow-pressure regulator. any one have a suggestion the flow-regulator can be replace it an gasket around 1250.00 pump new remand pump us 1549.96
