what type of oils / gear lube?
ghuds
Need to change all the fluids on my Model 70. What type / brands of oil and gear lube should I use and where? I have a manual but I was wondering what most people use. Any help is much appreciated!
I use the fallowing in all my 2 cyls tractors JD hi guard in the hyd, power steering and pto clutch 90W in trans and rear end run Mobile delvack 1300 15w40 in all my engines
Interesting question, my 70 is gas and I am curious as well, not sure if I can get some of the oils today that my manual recommends. I have oil running from my transmission into the pto on mine and am getting ready to tear into it to see how to fix it. My manual says 10 weight oil goes back into the pto but can't find it online. If hygaurd works I'll be happy. Can't wait to read what y'all use!
Hyguard works a likes dream in the hydraulics, I'm running my A the same as Kent except for the Rotella 15w40 engine oil and if the world changed tomorrow and his Mobile delvack 1300 15w40 was all I could get, I wouldn't think twice to switch over -- it's a fine oil too.
Baker valve and remote cylinder have over ten years on Hyguard with no issues what so ever.
How do you know you have oil running from the trans. to the PTO? PTO too full? I'm interested in what you find. Keep me posted.
That's my thoughts. Pto too full but both transmission and pto are light brown and over full so maybe they both are overfill due to condensation. I been running hygaurd in the powertrowl for a few years now cause I share implements with the newer tractors
we never consider this,but if we use hydraulic cylenders on many machines ,pull them with different tractors even brands and they hold any oil at all has anybody considered the mix its making in the hydraulic system? a round bailer has some healthy cylinders .reason I say that I have a cockshutt that always had atf in the system.id hook to a disc and then another machine .we used 1ow in our john deeres . id check my oil and it would turn brown. when I changed oil in my system I just used what we used in our joh deeres. never had a problem either
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]How do you know you have oil running from the trans. to the PTO? PTO too full?[/i:654c4848f0][/b:654c4848f0]</font>"
Yes, if the transmission oil is leaking into the PTO clutch housing, then oil will over flow out of the PTO clutch housing when the filler plug is removed.
Take a look at the photo below.
a232159.jpg" width="650"
Hope this helps.
Take a look at the lubrication check list for "Vernon" our 1956 Model 70 gas tractor.
[b:654c4848f0]Oil filter TSC C139PL JD AR 2811 R
Oil filter cover plug 1 ?? Socket
Crankcase drain plug 1 ?? Socket
Crankcase Flushing (diesel) 1 Gallon
Crankcase oil SAE 30 11 Quarts
Air cleaner oil SAE 30 2 Quarts
Transmission fill plug ?? Drive
Transmission front drain plug 1 ?? Socket
Transmission rear drain plug 1 ?? Socket
Transmission Flushing (diesel) 3 Gallons
Transmission oil SAE 140 7 ? Gallons
First reduction gear cover filler plug 1 ?? Socket
First reduction gear cover drain plug 9/16? Box
First reduction gear cover oil SAE 140 1 ? Quarts
Powr-Trol housing filler plug
Powr-Trol housing drain plug 9/16? Open
Oil level test cock
Powr-Trol oil SAE 30 6 Quarts
Power Shaft Clutch housing filler plug
Power Shaft Clutch housing drain plug 7/8? Long Socket
Power Shaft Clutch Flushing (diesel) 1 Pint
Power Shaft Clutch oil SAE 10 Fill to threads (2 ? Quarts)
Distributor Shaft SAE 20 Above shaft
Power Steering AF2235R ?FULL? mark
Cooling System 50/50 7 ? Gallons
Lower Pedestal Bearing Grease
Brake Pedal Shaft Light Oil[/b:654c4848f0]
We actually use 15W-40 Diesel motor oil in the crankcase.
We actually use 140W GL1 gear oil in the transmission.
Hope this helps.
