Cody Meister 2
The gauges on my late 4 post 4430 seem to have a grounding issue or some type of electrical issue, not exactly sure. Fuel reads in a different spot each time its started, oil pressure is usually showing in the red but some times goes way high, volt meter shows the needle dead all the way to the left always, and the water temp always shows very cold.
I'm wondering if this is a ground issue or what else it could possibly be. A bad ground seems like its going to be a bear to find so any tips or tricks will be appreciated!
