I posted earlier how the brass clutch fork blew apart and wrecked the sleeve making the clutch what I thought was stuck in the engaged position. Well, I bought a used clutch drum assembly including the sleeve, gear and bearings. I re assembled the clutch and it does not "snap" into engagement or disengagement. It freewheels when the lever is straight up, and the brake works when pulled back. When pushed forward the clutch starts to engage, but does not snap into position. Also should the drum freewheel when in gear with the clutch disengaged? I also bought a new clutch disk kit with springs and castle nuts.
