37b clutch cover holding tabs
Jdr315
Two of the three spring clips that hold the clutch cover on are broken. Is there anyway to replace just the spring clips or replace the whole drum?
Definitely! You can go buy part number B141R and rivet it on. Steiner has a reproduction one with a rivet for $14.95.
Take the clutch apart take it off the tractor and put it
on a bench . Drill out the rivets use a little bottle Jack
to push the spring and rivet in and peen the rivet in
place . Not a bad job .
like $25 at your local leaping deere dealer.id ordered 1 from steiner but didn't have the time so {GULP} went to our local dealer n they had 5 in stock
