JD 1020 wet or dry sleeve??
old
So I have this 1020 in the shop and the owner says it is getting some antifreeze in the oil and wants me while I have it to check into what is wrong. So is this a wet sleeve engine or dry?? Figure it it is a wet sleeve engine I'll pull the oil pan and let it sit and see if it drips if a dry well then it has to be a head gasket or something like a cracked head.
Thanks.
Little to know history on this one the guy just got it a couple months ago
Time for an out of frame rebuild with high compression Pistons . I'll bet the cam and followers are worn too, nobody seems to look at them unless the cam is actually broken.
