Fred from MO
I worked on my 60 over the weekend trying to fix the falling rockshaft problem. The rockshaft will lift, but it wont stay up. I have fixed this in 2011 by adding a new o-ring and leather on the internal piston (going from the back of the tractor not removing the rockshaft housing). This failed last fall so I fixed it again last fall. Now it failed in June. So this time I felt around in the cylinder and found one spot where my fingernail would hit a rough spot. The o-ring and leather looked Ok on the piston, with one spot perhaps a little wore on the rubber o-ring, but it didn't look bad at all. See the picture of the piston below. I did take a india stone and work over the "bump" in the cylinder to smooth it down just a bit. I put everything back together and the rockshaft is even worse falling faster. I don't know if its because I stoned the cylinder or the gasket between the throttle valve and the rest of the power trol housing is missing when I put it back together. Im not sure exacly how the power trol works. Correct me if I am wrong, but the hydraulic pump on the governor housing is always running when the gear on the pump is engaged-correct? So the fluid circulates back to the power trol housing and back to the pump until the lever on the power trol is pushed one way or the other. Then fluid goes into the rockshaft housing via the throttle vavle right? What keeps the fluid in the rockshaft housing, hence the rockshaft piston under pressure? Is it the checkvalves in the power trol? I pulled the check vavle and inspected each ball, but there was no smoking gun? I have read that deere has a publication specifically on the rockshaft operation and housing. Does anyone have that PN handy on the power trol manual? In times past replacing the O-ring and leather on the rockshaft piton had worked. Now I am wondering if the rockshaft cylinder is too far out of spec? See pictures?
