Hotflashjr
- Location
- Western MA
Installed new positive and ground cables on the 2550. I ended up using two AR53999 cables from Deere. Ran the ground cable to the bottom starter mounting bolt. Worked like a charm! This thing spins over and starts so much easier now. If I had run to the top starter mounting bolt I would have had way too much cable using the AR53999 from Deere for the ground. Going to the bottom bolt took up the slack and with a few zip ties I was able to get a good clean looking install. I am going to use a paint marker to mark red + on the positive wire and a silver paint marker to mark - on the ground wire since I used the same cable for both connections.
