5010 I to 760 scraper salvage yard
fdt860
I am looking for final drives for 5010I or 760. Idea is to get a fast 5020, my understanding is that I can swap trumpets, keep stright bar axle off the 5020, and now loop along with my 5020 at 30MPH at 2200rpm with 20.8-38.
Do you know where I can find those parts? And also if a 700 would have had same ratio final drive than a 760?
I wan to swap final drives:
The 5010scraper-760 has a much bigger sun gear, in 2 pieces. So they go quite much faster. I hope that the ring gears are the same.
(quoted from post at 06:17:42 07/11/16)
Sorry for confusion but I was aware of your intentions. As I stated RG/pinion are identical.
After digging more into it, now I think that I should get a 760A complete, a 619, a 4020 first gen powershift dash, a 7520 hood with his air filter, few parts, a scrapped 5020 with 3 point, and make a 5020-6630ish powershift.
Well, my wife would have a problem with this I guess, maybe later.
The bottom line sum might still be cheaper than a restored 6030, but hours can be countless.
