JD MT lift arms
moetrucker
New User
Removed the 2 long bolts at the pivot points underneath the tractor...There seems to be some sort of bushings that hold those lift arms in place when bolts are removed...feel like there are threads inside those bushings...
Wonder what it takes to remove them so I can remove the arms...
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]Wonder what it takes to remove them so I can remove the arms...[/i:654c4848f0][/b:654c4848f0]</font>"
Take a look at the diagram below.
a230933.jpg" width="650"
Note the locking holes right lock bracket (Key 34) and the left lock bracket (Key 35).
Also note the drawbar lock mechanism (Keys 25, 24, 23, 26, 27, 28, 29, 25).
Check both lock brackets to make certain the drawbar lock pin (Key 26) is not latched into one of the locking holes.
Take a look at the photos below of "Mac" one of our MTs.
a230934.jpg" width="650"
a230935.jpg" width="650"
"<font color="#6699ff">[b:654c4848f0][i:654c4848f0]There seems to be some sort of bushings that hold those lift arms in place when bolts are removed...feel like there are threads inside those bushings...[/i:654c4848f0][/b:654c4848f0]</font>"
Note the anchor pin bushings (Key 4) and the anchor pin (Key 36) in the parts diagram above.
Take a look at the photo below.
a230936.jpg" width="650"
Hope this helps.
Yes, that last picture from underneath - the 2 castings with the 4 bolts - remove both of them...and the hitch drops down out of the way...
