I'm doing some routine maintenance. My op manual says i should put 6-8 shots of grease into a grease fitting for lubrication of the rear axle bearing. problem is i have 1/4" (or 3/8") plugs where the op manual says there should be a grease fitting.
picture shows right side of rear axle from behind the tractor. there is a plug in the same location on the left side of the axle.
normally when i see a plug on an axle i assume i would check and fill with 90wt. oil.
what is the purpose of the plugs ?
I think I have a 1969 820. its a 3 cyl diesel. my op manual ( OML29340 ) has some inconsistencies. for example i have 1 fuel sediment bowl, not 2. I have no assembly/housing for an air filter element and rubber dust valve.
thanks in advance for any clarity and help.
Mo
