Harold Melius
I have a 1962 JD 2010 diesel (Serial number in the 17000's) that I am rebuilding and I need a little info that I can't seem to find. The tractor is set up as a 12 volt system, but I am seeing some things that lead me to believe it may have been 6 volt originally. I am concerned about the fuel sending unit, glow plugs, etc. being compatable if it was originally a 6 volt system. None of them were working when I got the tractor. Also, does anyone have any idea what the end gap on the rings should be. I don't usually work on diesel engines. I usually go with about .004 in. per inch of ring diameter for gas engines, are diesels done the same way? Thanks.
