JD 2555 cab clutch pedal adjustment?
Tx Jim
I'm attempting to help someone on another forum. Anyone know correct procedure for checking/adjusting free travel for clutch pedal on 2555 with a cab?
Thanks,Jim
If it has the SGB, it should have a hydraulic clutch engagement, not sure if they can
be adjusted....never did mine. Ben
Only thing I know is not to invent the procedure yourself, go by the manual. Whatever it says, in sequence. Ive found on my tractor that what I just by-gosh assume, is not right. The manual will tell you.
hello, the clutch system is self adjusting, NO adjusting required.. IF you replace the MASTER cylinder sometime
then you go by the book for initial pedal setting,, then you forget any further adjustment.
