3130 clutch (pic included)
Okay, not sure where to go from here. My tractor doesn't have a grease fitting. My serial number is 301017. I have included a pic looking down into the inspection hole. What are my options? anything else I can try or check at this point?
Since your tractors clutch is slipping all you can do is be sure TO brg has clearance between it & pp fingers. If clearance is correct and clutch still slips then it's time for clutch/pp replacement
