Model 70 Clutch problem
ghuds
Went to move the tractor and the clutch is stuck engaged. There seems to be a small piece of metal loose inside of the clutch drum. I'm planning on taking it apart, but I don't know much about the tractor so any help would be much appreciated! Any ideas on what might have broken to cause this issue?
Thanks!
I had the same problem last winter, I can't remember if I ever did figure out what the problem was. I removed the pulley and greased the bearing, installed new dogs, toggles, operations bolts and springs and put it back together and havnt had any problems since. I have a service manual which helped me a lot. There are some you tube videos that show you a lot but I think they used a 720 in the videos and I think I noticed a few differences. The videos were a great help as well. Then every one on this site coached me through it. It's really pretty easy.
Thanks for the advice, I really appreciate it! Had to take the loader off to get to the clutch. Next project is teardown the clutch. Thanks again!
