JD 800 Swather starter
Jd44A_1
Need some help on a 800 swather starter.
Replaced with reman about 2 yrs ago. Now it
needs rebuilt i think and theyre spendy at
about 500 bucks and no rebuild parts
available. Its a slant 6 and takes a
different starter then chrysler starter.
Miller or something like that. Cant remember
for sure. Is there another starter thats
cheaper route ??? Thanks.
Dunno where you get "miller", but a starter for certain manual transmission mopars of that era will work, IIRC, even for some 318 applications. Probably pickups and MD trucks. Depending upon serial #, the 800 could either use an inertial drive stater, or a gear-reduction stater.
Probably 15 years since I've dealt with it, so I can't be more specific, offhand.
Trouble is that they're old enough by now the local parts store probably isn't going to have a selection on the shelf to compare yours to.
ANY surviving nearby auto electric rebuilder should be able to get parts for it, though.
See if the parts store can cross:
Prestolite... MHA7014
Wilson... 91-06-1911
Mopar... 2642 692
There is a free parts book on the JD web site with some interesting info.
STARTER ASSEMBLY
SERIAL NO. ( -270722)
Cart KEY PART NO. PART NAME QTY SERIAL NO. REMARKS
1 E50031 BOLT 2 (CHRYSLER NO. 1889 080)
2 AE29707 COMMUTATOR HOUSING 1 (CHRYSLER NO. 1889 363)
3 AE29696 KIT 1 (CHRYSLER NO. 2525 529)
4 AE29698 HOLDER 1 (CHRYSLER NO. 1889 044)
5 AE29709 FIELD WINDING COIL 1 (CHRYSLER NO. 2084 088)
6 AE29713 STUD 1 (CHRYSLER NO. 2084 094)
7 AE29712 SOLENOID 1 (CHRYSLER NO. 2642 961)
8 AE29710 CONTACT 1 (CHRYSLER NO. 2084 091)
9 AE29714 PLUNGER 1 (CHRYSLER NO. 1889 151)
10 E50030 SEED BOOT 1 (CHRYSLER NO. 1889 147)
11 AE36211 STARTER MOTOR 1 (SUB FOR AE29695)
12 AE29693 FORK 1 (CHRYSLER NO. 2084 093)
13 AE29694 STOP 1 (CHRYSLER NO. 2448 804)
14 E50029 BEARING 1 (CHRYSLER NO. 2098 986)
15 AE31197 HOUSING 1 (CHRYSLER NO. 2642 693) (SUB FOR E50028)
16 AE29692 CLUTCH 1 (CHRYSLER NO. 2642 506)
17 AE34234 THRUST WASHER 1 (SUB FOR AE29708)
18 ........ FRAME 1 (SUB AE28905)
19 ........ SHOE 1 (SUB AE28905)
20 AE29697 SPRING 1 (CHRYSLER NO. 2084 666)
21 19H1978 CAP SCREW 2 7/16" X 1-1/2"
14H1047 NUT 2 7/16"
22 AE29711 COVER 1 (CHRYSLER NO. 2084 090)
.. AE28905 STARTER MOTOR 1 COMPLETE WITH SOLENOID (CHRYSLER NO. 2642 692) (SUB AE36211)
STARTER ASSEMBLY
SERIAL NO. (270723- )
Cart KEY PART NO. PART NAME QTY YEAR REMARKS
1 AE34233 BOLT 1
2 T19506 MANIFOLD 1 (SUB FOR AE34228)
3 AE34234 THRUST WASHER 1
4 AT17844 BRUSH 1 (SUB FOR AE34235)
5 AE29697 SPRING 1 (SUB FOR AE34230)
6 AT17842 PLATE 1 (SUB FOR AE34229)
7 AE34223 ARMATURE 1
8 AE34232 STUD 1
9 AE34226 SWITCH 1
10 AE34231 SOLENOID 1
11 AE34224 BEARING 1 INTERMEDIATE
12 AE34225 BENDIX DRIVE 1
13 AE34236 HOUSING 1
14 19H1978 CAP SCREW 2 7/16" X 1-1/2"
14H1047 NUT 2 7/16"
15 T19510 BUSHING 1 (SUB FOR E57479)
16 AE34227 FIELD WINDING COIL 1
17 E60702 PIN 1 1977 -
18 AE36211 STARTER MOTOR 1 COMPLETE WITH SOLENOID, (SUB FOR AE28905 AND AE34186)
Its a Wilson starter and NOT a MILLER !!! Sorry for the confusion. If I remember right we tried a slant 6 starter and it wouldnt work. May grab one from the salvage yard and try it myself to see what the difference really is.
