MaverickM23
On my 4320 when I got it the cab accessories wouldn't work I checked all the wiring and switches and found that the relay under the dash was only putting out 8 volts to the accessories in the cab. I got a new one from the dealer which is different than the original looks just like a car starter relay and everything worked great. I started mowing last nite turned the blower on and it worked for only ten minutes then everything quit and now when I turn the key the relay won't even click so I'm not getting any power to the accessories. What would cause this? I'm thinking I need a different relay like the one I took out which is a round one that has a different part number ar78382 the one I put in was # ar54484 could that be my problem? Thanks
