A little history, while I was fixing this tractor up I discovered the rockshaft control valve housing had the follower installed in the wrong spot and had it out of time. After about 5 attempts I managed to get it retimed and working sorta right.
Onto the problem, dad was plowing with a mounted 3-16 plow, started with the the load control in Depth, it would lift it all the way up. When he put the control in L-D it wouldn't lift high enough to clear the ground, so he left it in D. Came home yesterday and he had switch the plow to another tractor. It appears that it has gotten out of time again, I have a copy of the Deere tech manual to follow. I'm just wondering if there's any other adjustments or tricks I could try.
Thanks,
Mike
Here's a video of it plowing, still need to get the tires changed, but there's just not enough hours in a day.
https://youtu.be/ZzM7iKfsYPk
Thanks,
Mike
