430 transmission
kub6040
I was plowing today and 2cnd gear started making noise so
I went to first and had simulator noise not as loud so I
tried third and no noise but I can't hold on that fast so
where do I start? I don't want to break anything.
On my 435. I have busted the bull pinion gears. And the spider gears. Jack it up one wheel at a time and turn wheel and listen. I could feel it. Easy to fix. Can just take the final drive off. Each side. Not hard.
If that thing is making a sound like taking a small ball peen hammer and tapping on the torque tube and the tick/noise goes faster and slower with the speed, I say Vic has the answer.
That is the way mine sounded when I shelled some teeth or parts thereof off the pinion gear.
As I foggily recall, there is a cover on the back that you can remove and shine a flash light in and look.
