4230 select control valve
eamay
New User
I have a 4230 that leaks off on the left select control. I can flip the lock in/out( the far to the left) to out and it will maintain position under load. Is the valve AR 86535 needing replacing, and if so how do you set it correctly, or is there a need to adjust? Do I need to replace all, or just one? Put up with this for years and it is getting worse. Thanks for any help or suggestions. This site has sure been a blessing sometimes.
Usually all four valve need replacing when one leaks as the others are worn too. There is a special bracket/tool used to hold the valves in place while you adjust the internal cams/lobes. It is hard to adjust them correctly with out this plate
