So still working on a g, and took the valve cover off to check the valves. Everything looked good, but as I was putting it back together the little rubber gasket that the breather tube goes into was destroyed. I looked the part up in the parts manual and it lists it as D90R. If you Google that it comes back as a governor weight. Could the parts manual be wrong and it actually be B90R? That would be the same part as the B series if it is. Thanks.
Also looking for a F708R, pto seal housing, where might be the best place to look? $75 on eBay seems a little high.
