shugy368
Hi guys, uh, and gals, I reckon there must be a few here, any way I started to re-tension the tracks on my 420 C today and found the right Idler bracket assembly has a serious bushing /thrust plate and shims problem, not to mention the bracket itself is beginning to oval the shaft receiver hole. Sorry, I got off on a novel when all I wanted was a good parts source for this old beast. Any
:idea: would be appreciated
(quoted from post at 22:55:33 05/16/16) Hi guys, uh, and gals, I reckon there must be a few here, any way I started to re-tension the tracks on my 420 C today and found the right Idler bracket assembly has a serious bushing /thrust plate and shims problem, not to mention the bracket itself is beginning to oval the shaft receiver hole. Sorry, I got off on a novel when all I wanted was a good parts source for this old beast. Any
Not sure where your located but you might want to try Farmer Johns Parts 404-569-3093. He is North Ga. and on the net. http://farmerjohnsparts.com/
(quoted from post at 07:32:41 05/17/16)
Thanks all will give them a look, pray for me :roll:
