Model 60 brake drum oil leak
edinmo
Gear oil is migrating out to my brake drums and out the rivets of my Model 60 tractor. Will replacing the bronze bushing cure that problem? Couldn't find any info with various search criteria. Thanks for your help.
May want to check the trans oil level.If it is overfull it will leak out the brakes.
If the transmission has to much oil your right hand side crankshaft seal or shot and leaking engine oil into the transmission.
