3010 hydraulics
craigco
On the 3010 when using the scv it won't hold implements half way. It always raises clear to the top. But if you have it bottomed out it stays put and doesnt mive up. Is this normal or what should I be looking for? Thanks
It sounds like the valve is leaking through,, on those it's best to swap it out with a used one,, they are not friendly to work on..
