Loran Rygh
New User
I have a John Deere 5010 that the 3 point wont work. Everything else works as it should, the dual hydraulics, brakes, steering etc. When I move the level on the side of the rear end for the 3 point it doesn't do anything or make any noise. I was thinking if would be possible that a linkage or something came off inside the rear end. Any info or insight would be appreciated. Thanks
Do you have lever(parts key 51) on dash pushed forward? It's possible cable is faulty or is slipping in mounts.
Yes, the lever is forward and I
followed the cable down the the side of
the rear end, and the cable is moving
the lever as it should.
I was thinking about that.
Could be stucks gears inside and cotter pin 16 broken?
The big HEX plug to adjust the valves should allow to see if your valves are moving.
I meant cotter pin 26?
A lot of cheap stuff can go wrong. Or 3pt was removed and not put back right on the rear axle?
