37chief
Location
California
I need to locate a JD used parts supplier. Now that I have the part numbers for a top link assy. Another question. I have a JD 401 industrial. with a 4 cylinder diesel. I am sure it is the same as a ag tractor. Anyone know what ag tractor may be the same. Thanks again Stan
If its a early 401 it probable has 202 ci. engine / same as 2020 ag. tractor .. If newer '72'-'73 & up, yr. 401B has 219 ci. / same as 2030 ag. tractor.. Are you looking for R70183 center link [body] I may have one / I think I even have a complete adjustable 3pt. hitch
From my parts book I need the threaded shaft with the round bushing no., T25836. It measures 21 5/8 inches end to end. If you have something that will be great. I don't need the bottom end which has the threads inside It is a R48595. The whole thing together measures 26 1/2 inches end to end, with it screwed together all the way. If you have one and don't want to separate them I will purchase the whole unit.Thanks Stan
Is this what you need? Email if you want it ordered. It's aftermarket but new.
