Engine specs for a D
Patsdeere
Working on an unstyled D and have the head in the machine shop. The shop was asking if I had specs/tolerances for valves, guides, spring strength, etc. Is there someplace where I might find that info?
Thanks.
Great. I figured they had to be somewhere, and I know I had them for a case, but couldn't remember ever seeing them for a Deere.
Per sm 2000
D - serial 30400-109943 -valve guide id- orig- .6250-.6260 - ream to .6759-.6280 / length of valve guide - 4" / distanct of guide from head-1 3/8 /diameter of valve stem .6220-.6220 / angle of valve 30 / angle of seat-30 / width of valve head-intake-2 11/16 - exhaust-2 11/16 / width of seat 5/32 / springs- compress to 3" -lbs pressure - 50 - 75.
Serial-109944 and up - valve guide id - same as above / length is 5 1/16 distance of guide from head-1 5/8 / diameter of valve stem and aggle is same as above / valve head width- 2 3/4 / intake and exhaust / width of seat is same as above / spring compresses to 3 3/8 / spring pressure is 58-72.
Now my typing finger is whooped.lol
