StrikeForce
Seeking advice from those with more experience than I. The steering box on my 1952 John Deere A has about a 1/2 turn of steering slop to it and when I pulled it onto the road last weekend, well, I don't want to do that again. I've seen reference to a steering box rebuild guide? Any information or advice as to how to rebuild this component on the tractor?
The sector gear on the vertical shaft is nice and tight, has a good fit on the splines. I put a new bearing in on the outboard bearing but when the cover is tightened down, with no shims, the bearing is not tight. I think that is the source of my issue but I am not seeing how I can make it any tighter on the inboard bearing side. I have that tightened down the best I can.
So, death-wobble adjustments? TIA!
