tim s-tex jim-tech 7 and whomever can help
Tim, I sent you info months ago on this one, but am just now getting to it--3155-6100 hrs--jd265 sl loader-sg cab--little to no loader function--3 point extremely slow--600# standby press at rear scv-- sump screen had minimal debris at last service--"bucket test" on main pump look good---just now tested flow at return side-past reserve tank and cooler, just to check flow--looked good-- there was a piece of rubber gasket, Tim, in the fitting in the top of the pump at first test--kind of wrapped around inside, I thought I had found the problem, but not---I have a picture of it, if I can figure out how to send--may not be important--
--at low engine rpm,hi-lo acts like brake is on--in low side--tractor rolls easy if flipped to high-----if rpm increases low side frees up---if any of that helps
---don't know where to look for getting standby pressure up--trying to keep this short--shoot me an e-mail someone, if needed
