I have removed the failed lower needle bearing from my cast wheel standard axle. The JD repair manual says that the upper thrust washer (M427T) has ears which should be inserted in slots in the tube. Well, no slots, but the new washer does have the ears.
What is the bearing surface for this thrust washer supposed to look like?
Thanks in advance for your time and trouble to reply. Also, I assume my email address is somewhere, feel free to contact me.
