5085M relay
Tim [GA]
There are two relays in the dash [57M8853]. the local dealer say they cross to another number but the new replacement relay will not work,because of terminal placement. The 57M8853terminal placement is the top 2 terminals are at the 12 and 6 [up and down] and the 3 other terminals are at the 3 and 9 position [across]. What is the correct part number or does some one have two of the correct relays. Thank you TIM
57M8853 subs to 57M9880 which part diagram is below in photo.
I hope you can answer my questions if you have time. A customer has a 4030 that will not go into "D" range. you can only hear the grinding of gears. Is this most likely the shift fork? and do you need to split the tractor at the clutch to trans housing and disassemble the trans. Is the D range on the lower shaft? I appreciate all of your comments to all of us here on YT.
