Our JD2130 came with a 21 spline PTO shaft. In order to protect the topper from over-revving we got a AT29707 6 spline 540rpm stubshaft - fitted it - only to find NO DRIVE!!!
It would appear that something has stripped between the gear on the end of the main driveshaft, the double gear on the idler shaft, and the last gear which rides on the 540 rpm stub shaft. - Is this common? - and if so which bit is most likely to have broken? - While it looks easy to remove the quill complete with stubshaft it looks much more involved replacing the main shaft plus gear that comes off the clutch.
Any advice welcome.
Any advice welcome.
