Lights on a 3010
craigco
Going to tackle the lights on the 3010 this weekend. The rear light housing has a sealed beam light in it, and behind the seal beam is a regular filament bulb like you would see for a red dot system. What is the purpose of this light bulb? Or should this not be a sealed-beam and two regular bulbs for red dot? Can't see how it does any good behind the light as it sets. The few parts houses list it as a sealed-beam for replacement. Thanks.
the red light is for the tail light on my old crawler there is a white light for field work and a red light for road transport
Lamp behind sealed beam is to give a red light when operating on road. Lamp aftermarket #1156 when turned on shines through a red circle in sealed beam bulb. Correct aftermarket sealed beam should #4409X
Thanks it has just a 4411 in now. Searching for the 4409x I see how it works. Will get it all working with what I have and get a bulb ordered.
