3010 tie rod adjustment
craigco
Have to replace tie rod ends on a 3010. Is there anything special to do for alignment? Plan on setting it to what they are adjusted to now, but it looks like the flare out a little. Worst case should I just make the front and back of the rim the same?
Thanks
I measure up the same distance on front and rear of the inside of the tires, then adjust to get 1/16" toe in.
The best trick I ever used to help measure the toe in: Jack up the axle so the tire will spin. Drive a nail through a piece of 2x4 and turn it upside down on the floor so nail point can scratch a fine line on tire as it rotates. Have to rotate tire away from point not into it. Do this on both tires, and you have a nice reference line from which to measure. Be sure to measure at center hub height. Front distance between marks should be 1/8 to 1/4 inch shorter than rear.
And that is Darn close to a 1/16" ;^),,,most of these old front ends have an inch of "Wobble play",, I get some in here that lay a black marks on the shop floor when I pull them in, I set them whether it's on the list or not,, just because it "Irks" me...
Thanks hoping just the ends need replaced and not the steering arm in the middle. There's probably a good inch of travel with all the slack. Hard to steer down the road.
