Supplier for block mounting bolts
E Needs
I'm working on a 1940 B and several of the studs where the block mounts onto the main case need replaced. Does anyone know of an aftermarket vendor for these? I think the part number is B1333R but I'm not sure.
I think those were studs with nuts and lock washers. Tractor supply has a good selection of bolts. Get some grade 8 bolts and make your own studs. That's what I do.
