young tractor
Hi guys,
I am working on the air conditioning of the new to me 4430. There is no cold air coming out. The compressor kicks on and off, so
it appears the fuse isn't burned out yet. I have cleaned the condenser and cab filter. I have checked all the lines for the A/C.
The one spot I see an oil residue is on the compressor. It is the opposite side of the fan belt and around where you would
recharge the system. I am totally ignorant to air conditioning so excuse the questions. What would be leaking on the compressor
there? I can't figure out what I could tighten. There looks to be a plate with a single bolt that holds the two lines going out
of the compressor. Could it leak there? Is it possible to leak out of around the 4 bolts that holds the compressor together? Is
this a sign my compressor is shot? Lastly, I was told it was a 134 system. How do I tell? I look forward to your insight.
Thanks for your help.
