Jdtractorman123
I have a 1961 3010 deisel Syncro range trans. Runs and drives good. I finally got to use the rear remotes on a pull type disc today and noticed after a few passes the rear remote hyd quit... I sat there and tried the 3 point and nothing either. I scratched my head and speed the engine up and nothing, the steering seemed a little slower than usual. So I got off looked around and started to disconnect the rear lines and I felt pressure on the line after I moved the lever, then all of a sudden the loft came up and the disc lifted up and the rear had lever clicked in the netrual position, I then got back on and it worked fine and the 3 point lift worked too. So I made a few more passes and it did the same thing... I was watching the rear scv lever and it looked like the lever was getting stuck and not returning to neutral position some times. Could this cause the 3 point to stop as well and is it "floating the hydraulics " causing the hyd pressure to neutralize ? I don't think the pump is bad but something is out of sorts ??? Any suggestions?
