A couple of daays ago I was doing some work with my MC, the blade starting acting light the fluid level was low, so I headed for the shop. Shut her down and waited an hour or so, went out and check for hyd fluid and it was eal low. Checked engine oil and it was real high. It was on full before I fired it up earlier.
I figured the seal in the pump was bad so I proceded to remove the pump.. That is getting more difficult as the years go by..
Upon pump removal, it appears that the either the seal backed out a bit or the cam shaft moved forward a bit. The spline adapter had been rubbing on the seal causing damage. The pump was rebuilt about 6 years ago. I think the seal was seated correctly.
Question: has anyone had the seal move or can the cam move forward and should I be able to check for that?
I am waiting for parts now so wanted to ask for advice.
thanks.
thanks.
