1964 JD 3020 gas
linkr
New User
My brother has the above tractor and needs to find a carburator for it. The old carb is marked Bendix but the number plate is gone. Any suggestions out there? He has the old core. Thank you in advance!
I have a Zenith that I just took off a running 3020. The Zenith was the better of the two carbs used on 3020's. I sell them for $500 reply back if interested and I will post contact info. Tom
(quoted from post at 16:02:37 04/08/16) I have a Zenith that I just took off a running 3020. The Zenith was the better of the two carbs used on 3020's. I sell them for $500 reply back if interested and I will post contact info. Tom
We have interest but want to be sure it will fit the tractor. Would you need to see a picture of his old carb to be sure?
I do not need a picture as there were only two carbs for 3020's and they will interchange but the Zenith is the better of the two carbs. You can call me at 608-623-2851 no suday calls please. Thanks Tom
(quoted from post at 17:51:44 04/08/16) I do not need a picture as there were only two carbs for 3020's and they will interchange but the Zenith is the better of the two carbs. You can call me at 608-623-2851 no suday calls please. Thanks Tom
Thank you! My brother Jeff will call you tomorrow ( sat) he is in Beaver Dam, WI . He is very interested in your carb.
