4630 transmission extra cap. pump replacement
John401
New User
I am replacing the original transmission pump on my 4630 with a extra capacity pump AR75648. How does the small oil tube AR78366 hook up? Does it bolt into the transmission? There is no threaded hole in the trans case to bolt it to. There is a oil tube that comes from clutch housing that is bolted to the case. The AR78366 will not bolt there. The line is also to short to hook up to the pump. It needs to be about 1" longer to reach the pump. It is a late 4630 with rock shaft and transmission cover off.
