johnyquest69
Hello and thanks for all the wonderful advice I have received here! I've been having several hydraulic problems with this tractor but this is what is happening now. My clutch feels soft and it wants to grind a little when I put it in gear. I checked pressure at clutch port and it was around 150. It seems to take a sec or so for pressure to build when I crank it. After I mashed clutch and released it went higher. Around 180 at app 2000rpm. I checked pto clutch pressure-180, and pto brake pressure-180. I checked lube pressure and it seems to be ok. No tach but about 50# at app 2000rpm. Any ideas on soft clutch and grinding? Thanks, John.
