2355 Brake Valve.
RLA
Have a friend looking for 2355 4wd open station Brake Valve.
If I understand the J/D Parts Book correctly 2755 might be the same?
AL69166? His isn't rebuildable it's cracked . Looking for Used
Any leads will be helpful for a good Used or rebuildable part..
There is a ball bearing used to plug a bore on them, when it blows out it leaks pressure through ,,check and make sure that could be the leak, if it is I tap them out to a pipe plug...
Here's a list of possible donor tractors
