I got my PS manual and read through it once so far. The PS system now makes sense. I have disassembled the worm housing and valve assembly. Just wondering what parts should be replaced while its apart. It needs new bearings (front worn one fell apart) going to put in the 2 dowel pins (don't see a lot of wear on them) in the Steering sleeve. It has the special set screw in the sleeve, is there a reason to replace this? There is a little wear on the side. But is expensive for what it is. Does this cause issues?
And one small shim or washer that I am not sure where it came from yet.
I haven't started to take apart the pedestal yet. Not sure if I will have enough time doo do it.
