K Effective
I have re-started working on my project tractor- a 1996 Deere 5500N cab tractor. I have spent quite a bit of time repairing this unit already, but hit a couple of brick walls and stopped for a couple of years (okay, more like 5...). Whatever. Last night I started to drain the hydraulic fluid, to replace fluid and filters and clean the suction screen.
When I removed the front transmission drain plug, I had this object drop out almost right away. Any guesses what it might be and how concerned I should get?
Wherever this came from, it does not look worn or broken. Looks to me like a pin of sorts, too good to be a roller from a bearing. Thanks for any help provided. And by the way, who designs a tractor that requires the drawbar frame and hitch have to be removed to pull the hydraulic suction screen?
